It is currently Thu Jun 05, 2025 12:29 pm
PostPosted: Thu Apr 09, 2009 12:37 pm
After thinking about it for a few weeks, here are the jigs and photos of a way to make a Spanish neck/peghead joint with a bandsaw and disc sander and a way of making slot heads.
Here are the 5 jigs needed...
First is a jig to cut the shoulders...
In use...
Next are the two jigs to cut the angles. they must have the same but opposite angle. The jig and workpiece both slide through the saw...
The other side being cut...
Next is the jig to sand the angle on the peghead...
The jig in use...
Here is the setup to cut the V in the headstock. Note the angled carriage that holds the headstock. I recommend clamping the whole assembly together...
In use...
The other cut...
The completed joint...
Here's how I do the slot head...
Holes are drilled for the tuners...
The outside ears are sliced off..
First the short cuts are made...
Then the long cuts. It takes a few passes and you have to flip it over a couple of times to get the stock to the fence...
The pieces...
Glued up. Here's the trick. Leave the bandsaw marks and you will be able to hide the joints very well. You can insert dowel pins into the tuner holes to keep things centered...
Using the angle jig, glue up the neck and headstock...
Here's a close up of the glue joint on the slot head...
Enjoy!
PostPosted: Thu Apr 09, 2009 12:56 pm
Nothing strange about slots for the side, but I have to say you are just plain cheating in regards to the slotted peghead. beehive Eat Drink laughing6-hehe [:Y:]
PostPosted: Thu Apr 09, 2009 1:30 pm
Haans, so in the second to last picture you have a peghead that has no holes drilled in it. Did you use a different technique for it or why did you decide to drill the holes in the traditional way?
A higher purpose for wood.
Rich Smith
Issaquah, WA
PostPosted: Thu Apr 09, 2009 2:14 pm
Country: Romania
That's cheating alright, I spend half a day or more rummaging through it with chisels and files gaah
Build log
PostPosted: Thu Apr 09, 2009 2:21 pm
True, but if the intent is for squared edged slots, your method it simpler than chiseling out the slot as a whole.
PostPosted: Thu Apr 09, 2009 5:17 pm
Ricardo, you can do it either way, but if you drill them later, you have to put some inserts into the slots so you don't get tear out.
I don't have a smart answer for cheating... laughing6-hehe ...if it's square slots I want (and I do) I'll cheat.
PostPosted: Fri Apr 10, 2009 7:05 pm
Country: Romania
Actually the quick method should work for rounded ends too, just make the slots appropriately shorter then use a file or maybe a drill press.
Build log
PostPosted: Sat Apr 11, 2009 7:09 am
Alexandru, it also might be possible to drill the end holes first and then saw off the ears and make the long cut on the middle part. You would have to be very careful to get the sawcuts right. My original idea was to save a lot of time by not having to square out round end slots.
PostPosted: Mon Nov 30, 2009 4:01 am
First name: Rob
Last Name: Thompson
Me like your slotted head cheat! [:Y:] Joint is indeed just about invisible, and ya gotta wonder if the glue line there isn't stronger than the natural wood. John Greven has a demo on his site for a different, perhaps stronger seeming, version of the volute joint. Click on extras, then 'bird's beak demo'. Pretty cool.
Peace,
Sanaka
...imagine there were no hypothetical situations...
